Replacing Moen #1225 Tub/Shower Faucet Cartridge
Closed Thread
Old 11-03-12, 12:47 PM
D
I am trying to replace this cartridge. I have removed the retainer clip. I have tried pulling the cartridge out with pliers and vise grips, but it won't budge. Is there a secret to getting this cartridge out, or maybe a special tool?
Thanks,
Denny
Old 11-03-12, 03:01 PM
F
Received 36 Votes on 28 Posts
Both a secret (not really a secret) and a special tool. In the package with the new cartridge there is a white plastic thingy. You place this piece over the stem and then turn the thingy with a wrench. This "breaks" the seal of the cartridge in the body of the valve and allows for relatively easy removal.
Here is a picture of the thingy in the lower right corner.
[ATTACH=CONFIG]5059[/ATTACH] (Image courtesy of griggindustries.com)
If that doesn't work, and it often won't if the cartridge has been in place for a long time AND especially if you have hard water, then you need a "puller" tool like this:
[ATTACH=CONFIG]5061[/ATTACH] (Image courtesy of askmehelpdesk.com)
The puller sells for around $25 to $35 dollars depending on where you buy it. The homecenter may have it a bit cheaper.
Old 11-04-12, 10:23 AM
D
Got it fixed,
Thanks for the help
Denny
Old 11-04-12, 11:53 AM
F
Glad that you got it fixed. Did you get the cartridge out with just the plastic thingy or did you have to get the puller?
Old 11-04-12, 07:48 PM
D
The plastic thing did the job.
Thanks,
Denny
Old 01-12-13, 06:39 PM
lawrosa's Avatar
Super Moderator
Received 62 Votes on 54 Posts
Closing thread. OP fixed his issue.
