Leaking Faucet
Leaking Faucet
Hello. After seeing about 4 online videos about how to fix a leaking faucet, I tried to tackle mine. Of course, it's not like any of the ones I saw on the videos (which were all basically the same configuration). I had great difficulty loosening the stem as there was nothing to grip with my pliers, then found it doesn't pop up out of the sink like all the others I saw. It goes back down under the sink and is hooked up nothing like anything I've seen before.
Could someone help me figure out how to fix this leaking faucet?
So what do I grab, the white platic piece? Part of it is in the faucet handle it appears. Or do I grab the stem in the middle of it? Where do I get a replacement? Would Home Depot have it? This site didn't notify me of your reply, so I don't even remember how to get the valve body back into the sink.
Home Depot should have Delta cartridges if that is a Delta. Trying to get the best help on the weekend though might be a bit hard. If you go to the faucet section of the store you should be able to find it yourself. If you can't match it up there I suggest a plumbing supply house where the plumbers go as you definitely will get help there.
