Please help! Can't figure out why its leaking!
Received 0 Votes
Hello Everyone, I am new to this forum but I am hoping you can shed some light on my situation. We have an older house with tile walls in the shower. We have a shower/tub combination with a curtain. My bathroom is located on the first floor of the house and recently I have been noticing a tiny fist sized puddle on my basement floor. At first we thought it was coming from the tub so my husband recaulked around the the inside of the tub. When that didnt work we thought it was the floor. So my husband just yesterday redid a line of caulk around the bottom of the tub. It seems to have made it worse and it is still dripping from the floor you can see it! It is no where near any pipes and we just had all the plumbing redone a few months ago anyways. Any ideas?? It is driving me crazy!! Please help!!
Sounds like the plumbing you had done is leaking somewhere.
What type of plumbing was done (water feed to the bathroom and or drains)?
The funny thing with leaks is they'll redirect when passing through floors or ceilings, so it could be leaking one place, and finding an easier path through else where.
Does it appear only after showering or after a bath as well?
If you don't know if it's from the drain, fill the tub (plug in) with some water. If the water appears, it's probably not from your tub drain.
Received 0 Votes
I know nothing about plumbing but I will try to explain it as best as possible. The plumbing from the basement up to the shower was done as well as the shower head & faucet replaced. The plumbing was done last April. I forgot to mention that it ONLY happens when showering. Not when the tub is on or when it drains which was making me thing it was getting in the back of the tile or down through the floor. That's what is so strange. I would think if it was a plumbing issue it wouldn't only happen when showering??
Without tearing the walls appart, could the water be getting by the shower curtain onto the floor or a non-waterproofed portion of the wall?
The reason I'm asking is I have this same issue with one of our bathrooms. Because of the shape of the tub, if you don't pay attention (5AM get ready for work showers), it's easy for the water to get by the shower and on the floor. From there, it can leak through to the level below.
Received 0 Votes
That's what we are thinking! Because the floor is always a bit wet when we are done taking showers, we thought the caulking would fix it but it didn't seem too. Any ideas of what else we can try to stop it to see if that is the problem??
Another thought, too. If only when you shower, it could be a leak in the stand pipe from the control valve to the shower head inside the wall. May be difficult to tell, but if you aren't taking showers in there, turn the tub on, then divert it to shower and let it hit in the middle of the tub to preclude splashing. After a few minutes, go to the basement and look for the puddle. Let us know.
I would run the shower but collect all of the water in a five gallon pail so that no water goes down the drain nor ends up on the floor and see if you still have the leak. If so, it would seem to be on the supply side for the shower.
Received 0 Votes
Thank you all so much for the advice! I think I found the culprit. I was keeping shampoo & things behind the shower liner and as I was reaching through there to get things the water was sneaking out. This morning I moved everything inside the shower and made sure the curtain was fully closed. No leaks! So I am going to invest in some splash guards and a shower caddy. Fingers crossed that solves the problem!
Received 0 Votes
So I am just confused now. The floor was dry yesterday and it was wet again today! It is only happening sometimes, but always leaking from the same spot and sometimes only happens when one of us takes a shower! Tonight I am going to see if I can re create the leak again but I just can not figure this out!
Married friends of mine had a similar "can't find the cause of the leak" shower situation. It was in a ranch house, and the leak was water dripping from the bathroom floor down into the basement.
They caulked around the tub, made sure the shower curtain was inside the tub, etc....and still, the bathroom floor was wet.
They found the problem by watching each other as they individually showered. (I realize how weird that may sound, sorry!) Each one sat outside the tub, and looked for leak/drips as the other showered.....It worked! The culprit-my buddy's "big butt"-to quote his wife.
Evidently, when he bent down to pick up shampoo, soap, etc., his butt would push the bottom of the shower curtain outside the edge of the tub and result in the small puddle on the floor.
I'm not sure if that process would be helpful to you, but it seems like you have tried more standard approaches.
Good luck !
Good luck !
That is too funny! Thanks for sharing! Yes the more standard approaches are just not working!! Just out of curiosity, how did they fix it????
My buddy's wife suggested a smaller butt, however, that was not in the cards.
I hope that you can find the solution to your situation.
Received 0 Votes
Re shower leak.
Shower curtains are all prone to various problems, leaking onto the floor being the worst. Have you thought of fixed shower screens?
If the floor of the bathroom is tiled, you can get a tile sealer which should also stop any water getting through. That would need re-applying annually.
Good Luck.
Good Luck.
Received 0 Votes
Thank you all for the advice! I just wanted to update everyone on the problem. We FIXED it! Come to find out it was not the shower curtain or the floor at all. We have an older home so the bathroom has tile walls with the built in soap dish and what not in the wall. The water was getting behind that!! My husband sealed it with bath tub caulk and no more leak for 2 days now!! I am just glad it was an easy fix.
