Shower valve replacement
Old 02-16-13, 08:10 AM
I'm replacing my shower valve finally. There's copper behind the wall but I'm just going to sharkbite that to plastic to make the replacement go smoother/easier.
The type of fittings I bought to screw onto the valve are female brass to 1/2" pvc. If I'm using dope on those threads, is there any problem with "really cranking" them tight? I just put the valve in a vice and tightened them with a 12" crescent wrench until I was satisfied. Is there such a thing as over-tightening when it comes to that?
Old 02-16-13, 08:13 AM
lawrosa's Avatar
Super Moderator
Received 62 Votes on 54 Posts
Yes you can over tighten and crack the valve body. Since the fittings are tapered and the body is a soft mental it can happen. ( Has happened to me )
Old 02-16-13, 08:45 AM
do you suggest I just redo it with Teflon tape and less torque?
Old 02-16-13, 08:50 AM
lawrosa's Avatar
Super Moderator
No not if its already together. You used tape or dope?
Old 02-16-13, 08:53 AM
dope was used. will that suffice?
Old 02-16-13, 08:56 AM
lawrosa's Avatar
Super Moderator
I use a couple wraps of teflon tape and a dab of teflon paste.....
Not sure what dope you used...
Old 02-17-13, 06:20 AM
I used pro dope from home depot. I've had it for years but never liked it too much due to the mess.
As the nit pick that I am, I redid it with tape. Seemed smoother, I guess tape on tapered thread is a good plan.
Thanks!
Old 02-17-13, 07:28 AM
lawrosa's Avatar
Super Moderator
Cool .
