should I replace flexible tubing in bathroom sinks in condo?
We have a vacation condo which is about 14 yrs old. I have since replaced flappers on toilets as well as toilet inlet valves and supplies. I also replaced washer hoses with stainless.
Since we are only there every few months, we turn off water whenever we leave.
I am trying to see if I should replace any other things that might be prone to leaking.
The supply tubing under the sinks in bathrooms is a clear tubing with what looks like criss-cross pattern of fiber (like chain link fence). Not sure if this is actually cross-linked poly.
Should I replace these anyways? In our primary home, I have never replaced them, but I am a little wary of vacation place as we are not around very much. But I don't want to unnecessarily replace something that should be fine.
Thanks
Dave
Thanks
Dave
Ok. One other thing. With one of toilets, shutoff valve and inlet on toilet are very close together. I looped the shortest stainless hose I could find. I wouldn't say it is kinked tight, but is under some tension. Is that a recipe for a leak? Should I get a longer hose and loop it with idea it wouldn't form as tight a loop?
So i finally looked under sinks. Tubing in one bathroom is copper from shutoff to sink. In other bathroom, it is some type of solid chrome (?brass). Should i replace these or leave them? Thanks
I like getting longer supply's and putting a bigger loop as not to cause tension.
