Dripping new sink drain
Received 0 Votes
I need help. I installed a brand new sink on a vanity with a new faucet fixture and all new drain pipes. After assembling and checking it I see there is a very tiny leak coming from the sink drain flange somewhere. I used regular plumbers putty on the flange of the drain,, should that have been something else? I tightened the big lock nut under the rubber washer about as much as I think is wise but it still seams to seep. Should I have gooped the threads between the flange and drain tube? (I didn't) Any ideas? Like I said, everything is new,, no old parts. Thanks.
Depending on the design of the sink and drain you are using it may seal on the bottom side of the sink where the rubber washer and nut are located, unlike a kitchen sink where the plumbers putty is applied under the flange of the upper drain piece. I have seen many sinks with rough or sharp edges or a blob of resin on the bottom side where the rubber washer needs to seal. Sometimes cleaning that area where the washer meets will allow it to seal and sometimes I cheat and use a little plumbers putty on the bottom side with the the rubber washer.
Loosen the whole drain assembly and try it again. Sometimes, they just don't seat at 90 deg. to the drain hole. Try it again to make sure that is where the leak is. I still use Plumbers Putty under the drain lip on the top side, maybe more out of habit than anything else if they seal underneath.
