Shower Tub Bar Replacement
Old 08-19-13, 03:05 PM
T
What kinds of replacement can be used for a shower tub bar. As long as I know they won't be sold separately.
See pictures below.
Thanks,
Old 08-19-13, 07:01 PM
W
Received 12 Votes on 10 Posts
Hi, About 15 years ago we had the same problem. I did maintenance in Public Housing. The tubs brand name was something like Lasik. We went to the company, they came up with a kit that worked well. It was more of a saftey problem. I would see if you can get the name of the tub
(sometime they are embossed on the unit) Search the web or go to a big Plumbing shop. Maybe they can help.
Good Luck Woodbutcher
Old 08-19-13, 07:17 PM
T
I cannot see any name/brand on it. Where should I look for?
Old 08-20-13, 06:03 PM
W
Tub bar repair part one - YouTube
If you can't find what you need check out the Tub bar repair above. Copy it to your search engine.
Woodbutcher
Old 08-23-13, 03:27 PM
T
What kind of plugs like a plastic piece can be used to get the holes closed?
Old 08-26-13, 03:19 PM
T
No idea how to close the two holes?
Old 08-26-13, 03:22 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Go to a hardware or auto parts store with the exact size of the holes. Ask for help in the electrical and hardware section...someone will find something. Whatever you use you'll need to put some caulk on it to keep water out.
