How drain toilet for removal
Received 0 Votes
Getting ready to tile bathroom floor. In the past, I've turned off the water and flushed the toilet before removing, but this still leaves water in the base of the toilet and a mess when I move it. Is there a way to get ALL of the water out of the
base of the toilet before I move it?
Rags and a pail.
People seem to think its such a disgusting place to put you hand in. Its just water. If you clean the toilet first then just use you hands and a rag to soak out the water.
In addition to turning the water off and flushing I then use a plunger to force as much water out of the bowl as possible. Then I put down a piece of cardboard on the floor to protect it from wax ring residue and whatever water spills out. Other than that... wear disposable rubber gloves and keep your mouth shut.
