Toilet help
Received 0 Votes
Toilet help
Need some help guys! I'm trying to get my toilet up and running BEFORE tiling. Is there a way to do this - installing the toilet temporarily to the subfloor/cement board?
Received 0 Votes
Also, when I get ready to put the floor down, will it damage anything treating the toilet as a "toilet repair/install of new toilet", meaning taking the screws out of the flange to put the new floor in and then doing the toilet install?
Figure the height of the floor and install the flange... Install the toilet temporally as mitch suggested and yourself. Some scrap pieces of wood or flooring same height as flange. A couple pieces this way and thats way so the toilet sits on them securely... Dont over tighten bolts as you may crack horn..
The horn is the bottom of the toilet with the holes for the bolts, Basically you can crack the toilet if its not sitting around the complete base if you know what I mean...
