kitchen sink drain strainer: how tight?
Yesterday afternoon, I found a slight leak coming from the kitchen sink drain, right at the top,near the strainer/ rubber washer/cardboard washer.
I tried to tighten the big locknut, but the leak continued.
Last night, I replaced it all: new putty, strainer, 2 washers, locknut, and reassembled the drain. So far so good, after running a lot of water, no leak.
Currently, while there is no leak,I think that I could make the locknut tighter, but I don't want to over-tighten anything, and possibly cause another leak or damage the drain.
My question: how tight do I need to make the locknut? Do I leave it "as is", and only tighten it more if the leak reappears? or..??
Any suggestions are appreciated. Thanks in advance.
Run hot water down the drain for several minutes. Then give the nut a snug... If it snugs a little then it was too loose... If it dont budge with great effort then its tight enough...
I never leave a home without running hot water and snugging all nuts....
Wow, 2 differing replies from 2 gentlemen who have never steered me wrong.
So what did I do:
I checked the existing tightness, and it seemed like I'd need to apply a lot of force to make the nut tighter. I then ran hot water for 5 minutes, and tried again. This time, the locknut moved, somewhat easily, approx an eighth of a rotation before snugging up again. I left it at that, still no leak, but to be safe, there is a small bucket underneath the drain!
Thanks again, gentlemen.
Mike, a follow up question: what does running the hot water do, that shows that you need to snug things up a bit more?
So what did I do:
Usually on a call when a plumber does not do this, there usually is a call back for a leak down the road...
Why? Because the homeowner runs hot water, dish washer for a few days and the joint you thought was tight loosens up from expansion and leaks..
#1 call back a plumber faces is this IMO...
2nd trick is use teflon paste on all washers and threads...
I do this on track homes mostly... Why? Because the water is usually off on not on to the home yet...cant run hot water or leak test...
