Utility sink drain question
Old 01-30-14, 04:56 PM
I am looking to install a laundry tub (for use only for sink, there will not be a washing machine draining into this) and am curious on properly draining it. Firstly there is a 4" floor cleanout where I want to put the sink so I am looking to drain into that. I am mostly looking to find out if I need to vent this drain, and if so would a studor vent be ok for this.
I have attached a photo of a mockup for this. Any help is appreciated.
Old 01-30-14, 05:18 PM
I just thought of another question. If a vent is needed would it be ok to put a cleanout wye on top of this stack and reduce to 1.5" pipe to connect to either vent stack or studor vent?
Old 01-30-14, 06:25 PM
lawrosa's Avatar
Super Moderator
Yes you can put a clean out Y there... Yes a studor would be good... Put the sudor 3ft above the flood plane of the sink...
No to the vent stack if any waste flows through it... Needs to be a dry stack or vent...
Old 01-31-14, 09:14 AM
Ok, so just to confirm I can bring the vent up out of the 4" drain by reducing to 1.5". And I can either use a stupor vent, or connect to a vent stack if I'm sure it's a dry vent.
I'll probably go with a studor vent then since I'm pretty sure there is a dry vent across the room but I'm not sure I can be 100% sure.
