Toilet water supply
Old 01-31-14, 08:28 PM
Toilet water supply
American Standard calls for the water supply to a new toilet to be 8 inches from the floor. If I install it at 11 1/2 it is completely hidden from view, it does not touch the bowl or interfere in anyway that I can see.
Is there any compelling reason to keep it at 8" and have it much more visible?
Could it cause any issue with the speedway having it 4 inches higher?
Thank you,
Old 02-01-14, 12:47 AM
As long as it clears the toilet, allows for an easy bend of the connecting hose and is accessible you can place the supply valve anywhere you desire.
Old 02-01-14, 04:47 AM
Can you still get to the shut off valve with it "hidden"?
How do you plan on connecting the line to the tank?
Old 02-01-14, 05:12 AM
Thank you Furd.
Joe, there is a Pex line to the toilet, a shutoff valve that would require you to drop to a knee to close, but accessible, which is connected with a stainless speedway.
