Using caulk to seal cracks between tiles in shower wall
Old 02-10-14, 10:04 AM
In a year or 2 i will be gutting my bath, but i just saw some cracks i want to fill in the meantime. Is it ok to use caulk instead of grout for small cracks in the wall of a shower?
Old 02-10-14, 11:43 AM
Gunguy45's Avatar
Super Moderator
If you mean cracks in the grout between tiles...yes...they make sanded caulk that will work. Color matching is the hard part. If you don't mind that...then go for it.
If you are only concerned about water intrusion....if the shower was built correctly...it shouldn't be an issue. Grout is porous anyway.
Old 02-10-14, 12:12 PM
Thanks for the answer, Do i need to use sanded caulk?
Old 02-10-14, 12:18 PM
Gunguy45's Avatar
Super Moderator
To keep a similar texture...yes. If thats not a concern you could use anything you want.
Old 02-10-14, 01:55 PM
Great thanks again !
