Bathroom faucet leak: no set screw or manufacturer information
Received 0 Votes
I'm trying to fix a drip in my bathroom faucet. The faucet handles don't appear to have a set screw, or a cap that I can remove to access the set screw. I don't see any manufacturer information, though the spout has Perlator VX stamped on it (searching this name hasn't really helped me). Any ideas on how to remove the handles?
http://i.imgur.com/l6J7kE1.jpg
http://i.imgur.com/eOW60Aa.jpg
http://i.imgur.com/iyiveyY.jpg
I couldn't find any info on this specific faucet. This is often the case on off brands.
However, if similar to other brand faucets with this type of handle you should be able to do the following (It will depend on level of corrosion)
Hold faucet lever as is, pointing out left or right...
The hub below it, closest to sink surface should turn counterclockwise, lifting up handle.
You may need a strong strap wrench.
