Shower drain cover area disintegration
Received 0 Votes
The plastic drain hole cover in my tiled shower floor had come loose and when I removed it the concrete around it had disintegrated. If I put fresh tile grout around it and push it back into place will that be sufficient to use again? I don't really know what else to do with it but the man in Mitre 10 filled me full of dread!
Karin, welcome to the forums! Not sure what plastic cover you are referring to. Could you post a picture or two of the problem area so we can see what you are seeing? Thanks. http://www.doityourself.com/forum/el...your-post.html
Received 0 Votes
Hello and Thank you...I am not good with cameras but its the only drain hole cover in the floor of the shower, The little round white plastic grip / cap that stops things from falling done the shower drain pipe in the floor...it was loose and falling in the hole.... The cement around it has all disintegrated. I put the grout around where it come out butnow it wont sit flush with the floor tiles again, and I dont know whether I need to take all the tiles up, or get a plumber or whether what I have done will do...or what to do really. Do you want my phone number? That might be easier
Received 0 Votes
http://i1038.photobucket.com/albums/...g?t=1407441313
on this one you can see the ready mix grout stuff the Mitre 10 guy told me to get in the tube bottom left corner
http://i1038.photobucket.com/albums/...g?t=1407441299 this is the problem, the white plastic grid was falling in....is this grout fix up job going to be OK to use the shower again, please? Or will all the newly applied grout just fall in down the drain and cause a problem?
I hope the others will chime in on this, but it appears whoever built this shower used an in floor drain to allow water to exit. There is no ptrap. Only the floating ball. How it prevents gasses from entering the bathroom is a guess. How long ago was this installed? What is a Miter 10?
Received 0 Votes
the house is 7 years old its a Scott park home. Everything here seems to have been done on the cheap! what do I do now then?
Mitre 10 is a store where they sell home fix up supplies, like Bunnings but smaller
Received 0 Votes
I am guessing I cant be the only person to have had this....what did the others do I wonder? Grateful for advice. I'd go back to the builder to complain...but I think its to late now, it has to be within 6 years?
