Which Pipe is the Cold / Hot Connection?
I removed my kitchen sink faucet because I change counters but now to re install I don't know which is the cold / hot water connection. The only indication is that one pipe is longer that the other.
Thanks pugsi I know that, the problem with mine is that the faucet has 2 parts, the spout and the handle. The 2 pipes are in the handle and when I have the handle facing me (thats the OFF position) I have 1 pipe (the sort one) in front and the other pipe (the long one) behind. Therefore the hot / cold been on the left / right is not applicable here. I guess for the pipes to be one longer than the other it may mean something.
I think you mean the integrated hoses from the faucet valve, not pipes.
Manufacturers have different means of marking which line is hot and cold.
Delta will have the washers inside compression nuts colored blue and red. Red is hot.
Kohler will have a sticker on one of the lines marked cold or hot.
If the lines are braided, the hot may have red striping going all the way up the hose.
These are not hard and fast rules, just trying to give you an idea of what to look for.
You are right Brian, they are the integrated copper pipes, one is 9” long and the other 11” and the faucet is Delta but there are no markings of any kind to indicate hot/cold.
I guess I will have to take a chance and connect and if they are wrong than just switch as you suggested
Thank you all
Thank you all
Delta normally has blue and red plugs in the end of the supply hoses. Here is an off the wall check. Open the faucet to the cold position. Blow air through the supply hoses. One hose should let the air through. That would then be the cold hose.
