Sink trap, trap nut broken
Old 12-21-14, 03:43 PM
I
I've never done any plumbing repairs before. But I saw the nut was broken on my sink trap. I'm assuming I can't just get a nut for this. Can I simply replace this "J" shaped piece that goes into the elbow in the wall with one from a big box store? Would I run into any kind of difficulty with threads not matching up with the elbow that is currently coming out of the wall? Or how should I replace. Thanks!
Old 12-21-14, 05:08 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Thats an LA trap.. Just unscrew the large nut and the broken nut. Then replace broken nut and reinstall...
Replace washer under broken nut if needed....
[ATTACH=CONFIG]43634[/ATTACH]
Old 12-21-14, 05:30 PM
I
When I go looking for the nut at the hardware store what exactly am I looking for? Something called an LA trap nut? Is that a separate piece that is going from the trap to the silver pipe?
Old 12-21-14, 05:53 PM
chandler's Avatar
Received 6 Votes on 6 Posts
No, just a pvc 1 1/2" trap nut. Very common. As Mike says, just take the trap completely off and slide the nut down and off the metal pipe. Put your new one on along with a new washer with the wedge pointed down, and reinstall the trap. Done in time for the game.
Old 12-21-14, 06:09 PM
Handyone's Avatar
That looks like an 1-1/2" slip nut with an 1-1/4" slip washer (for the bath).
When you buy the nut chandler specified, make sure it has the 1 1/4" washer with it, if not purchase separately.
