Bathtub faucet broke into half and not coming out
Old 03-06-15, 11:34 PM
T
Hi,
I was trying to fix leaky faucet by changing its cartridge. Unfortunately an hour worth of project has became couple hours of nightmare.
I have looked at youtube but nobody has covered this scenario. The cartridge (Moen 1222) has broken right in the middle. I tried to create some leverage with a nose plier; the cartridge has started revolving but this damn thing is not coming out.
Any suggestion will be helpful. I will put some pictures for reference purpose.
Thanks, Sandeep
Old 03-07-15, 04:53 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Certainly pictures would help us see what you see.
Old 03-07-15, 05:12 AM
Norm201's Avatar
Received 255 Votes on 229 Posts
I suspect the cartridge was highly calcified and stuck. When using the pliers you worked the plastic to a breaking point. The whole cartridge was not turning only the front portion. You should've used an extractor (available for sale for just such problems). I had a similar problem but was advised by Moen to buy the extractor and not force the removal with a pliers. You may have to drill it out.
Old 03-07-15, 05:18 AM
Received 330 Votes on 293 Posts
Old 03-07-15, 07:59 PM
T
Thank you for your suggestions and replies. After unsuccessful efforts late last night; I woke up this morning and tried again. This time the cartridge was revolving easier. As suggested I drilled to create more leverage and wala the magic happened! Dripdy drop has stopped now! Thanks again- Regards, Sandeep
