Simple drain replacement on old sink
Old 03-11-15, 08:23 AM
biketrax's Avatar
Received 1 Vote on 1 Post
Doing a simple bathroom sink Trap drain replacement at a friends OLD house.
the mount against and into the wall has an original old worn cast iron 1 1/2 inch nipple.
My question concerns this wall tube connection. Would there be an issue or
any problem using a new Chrome plated brass (cheap china stuff) wall tube? into the existing wall which is cast iron??
I know there is always concern when two different metals have contact
I will be using plumbers tape.
thanks
Old 03-11-15, 10:20 AM
Received 1,180 Votes on 1,093 Posts
The two different metals won't be a problem there. You may even consider using plastic for the new drain and trap.
Old 03-11-15, 12:18 PM
F
Received 36 Votes on 28 Posts
Use a trap adapter, 1-1/2 inch threaded to 1-1/4 inch slip.
[ATTACH=CONFIG]47851[/ATTACH]
(Image courtesy of hdsupply solutions.com)
