What is this faucet type called?
Old 04-05-15, 09:10 AM
The outside faucet was dripping. I could actually see the cracked inside rubber washer and I thought, easy!
I removed the top nut thinking that the head section would come out but it seems it is a sealed plastic part.
Is this sealed or did it fuze with the rest of the faucet through the years?
http://imgur.com/jrB8Rzu
It did have a nut on top to keep it down so it should not be sealed.
Old 04-05-15, 09:38 AM
lawrosa's Avatar
Super Moderator
Received 10 Votes on 8 Posts
The stem should turn out counter clockwise. The packing may be holding it in and a bit or force may need to be used..
Old 04-05-15, 09:51 AM
Norm201's Avatar
Received 60 Votes on 57 Posts
It's called a hose bib. You may want to get a frost free faucet instead.
Old 04-05-15, 12:54 PM
Thank you guys. I will see if I can get it loose and replace the washer. If that fails I will call a plumber and have a new faucet installed.
