How to remove hand held shower mount
Old 08-03-15, 06:36 AM
I have an older Moen shower head and hand held spray in my master bath.
There is a cradle (not using the right term I am sure) attached to the wall (it is not part on a pole like the current models) where the hand held shower can be hung.
What I need to know is how do I remove the "cradle" from the wall as I don't see any set screws on it anywhere, so I am not sure how it is attached.. I tried to attach a 3.4 meg jpeg and doc file of the cradle but it would not upload.
Thanks
Old 08-03-15, 04:51 PM
If you are trying to upload your file directly to the forum you need to shrink the file size. I usually upload photos to a photo hosting website like Photobucket then I post the links here in the forum.
A picture would help alot. Some are porcelain and installed with the tile and are basically not removeable. Metal ones often have holes drilled through the tile or grout to hold a mounting bracket then the cradle clips over the mounting bracket so you don't see the screws.
Old 08-03-15, 05:54 PM
Gunguy45's Avatar
Super Moderator
It could also be held on with double sided tape and/or caulk.
