Kitchen Pullout spray won't separate.
Old 08-07-15, 11:02 PM
Hello!
My kitchen pullout spray's pressure is low, so I was hoping to replace it. But the spray head won't separate from the hose. Can anyone advise how I can remove it based on the photo attached? Thank you!
Old 08-08-15, 04:48 AM
Some models can not be disassembled so you need to also replace the hose.
Old 08-08-15, 05:11 AM
czizzi's Avatar
Remove the aerator on the end of the wand and flush out the debris with water. This should improve your water flow. Sometimes you need a special tool that came with the faucet if it is recessed into the handle.
