Sink paint ??
Old 08-19-15, 09:56 AM
Sink paint ??
Money is tight and I'm trying to get rid of some discoloration on the bottom of my kitchen sink. When I use bleach and other cleaners, discoloration goes away but it always comes back. Eventually I will have to replace the sink, but for now I would like to know if there is a special spray paint I can use for this problem with decent results. The color of my sink is light beige. Thank you.
Old 08-19-15, 10:05 AM
Received 120 Votes on 107 Posts
You could use a tub and tile paint but I don't know if they come in aerosol. They don't have a great track record although the number one reason for failure is improper prep. You'd need to remove the drain and clean well! IMO you are probably better off continuing like you have been.
Old 08-19-15, 10:44 AM
Received 194 Votes on 180 Posts
The discoloration is it a mineral buildup on the surface that holds dirt and mold or is the porcelain worn through?
I would not spend any money trying to paint or coat your existing sink. Just put the money toward replacing the sink.
