Sink Sprayer- What Brand is this?
Old 08-28-15, 06:37 AM
I need to replace my sprayer, but the connecter for the sprayer is not universal. I am thinking that I need to know the brand to fix this, and there is no indication of brand anywhere on the faucet. I am hoping that someone will know what brand uses this type of connector, or can advise me on what to do next. Thank you!
Size:  25.3 KBName:  image1.jpg
Old 08-28-15, 06:42 AM
lawrosa's Avatar
Super Moderator
Upvotes Received: 3
Could be anything....
Take a pic of the faucet and sprayer..
Often you can just replace the sprayer end and not the hose..
Welcome to the forums...
Old 08-28-15, 06:43 AM
Temporarily Suspended
Why didn't you include a pic of the sprayer, itself?
Old 08-28-15, 07:10 AM
Handyone's Avatar
There's not a sticker on the hot or cold inlet tube?
Old 08-28-15, 07:49 AM
Faucet
Here is the faucet.
When you say that I can replace just the sprayer and not the hose, does that need to be brand specific?
Let me also give you all some background on why I am replacing the sprayer. There is pulsating when I turn on the water. I have tried to clear the line of air, but no luck. The sprayer is leaking with the pulsating.
Your thoughts on brand and sprayer issues are really appreciated!
Old 08-28-15, 07:58 AM
lawrosa's Avatar
Super Moderator
Upvotes Received: 3
Looks like a standard delta faucet.. ( I could be wrong though)
Call delta and they may send you what you need for free...
Maybe even a new faucet...
The sputtering may be internal to the check valve in the faucet body...so changing the sprayer may not fix your issue..
Old 08-28-15, 08:04 AM
lawrosa's Avatar
Super Moderator
Upvotes Received: 3
Old 08-28-15, 08:07 AM
lawrosa's Avatar
Super Moderator
Upvotes Received: 3
I found this question and answer..
When water is turned on, there is a recurring "thumping" and subsequent leaking from connection on sprayer. Will new sprayer solve "thumping" issue?
Read more: RP54807OB Delta Spray, Hose Assembly and Spray Support : Repairparts Products : Delta Faucet
Hi Tim, Thank you for your question. Based on your description the most likely issue is the diverter assembly needing to be cleaned or replaced. The diverter assembly is usually located under the spout. Please refer to your owners manual for the parts breakdown of your specific model.
Thanks,
Dave
Old 08-28-15, 09:36 AM
Handyone's Avatar
RP54807SS Delta Spray, Hose Assembly and Spray Support : Repairparts Products : Delta Faucet
Lawrosa found your sprayer. It is a Delta. Above is a link to the sprayer in Stainless Finish. Like he said though, I would call Delta. They once sent me a new faucet and all I was asking for was a few small parts.
