Toilet flange too high
Old 09-13-15, 06:21 AM
After installing new wood floor, noticed that flange is too high for toilet. I'm considering taken a hack saw to the existing flange... Not sure if this is my best option... Help!
Old 09-13-15, 06:50 AM
Temporarily Suspended
Old 09-13-15, 06:52 AM
XSleeper's Avatar
How about posting a picture of what you've got. I would think that adding anot her layer of floor would make the flange lower, not higher.
Old 09-13-15, 06:59 AM
Take a the attached images to view my challenge Name:  DSC_0029.jpg
Old 09-13-15, 07:08 AM
Is there a cellar below the bathroom? If not, I would try to unscrew the screws, lift the flange & cut the pipe.
Old 09-13-15, 10:10 AM
ray2047's Avatar
Just curious. Did you pull out an old mud base tile floor or what.
Old 09-13-15, 10:40 AM
The flange isn't even parallel to the floor. Looks like the screws may have been used to force the flange down.
Old 09-13-15, 11:45 AM
czizzi's Avatar
Also curious what type of floor was replaced prior to the hardwood. This tells us how it worked previously so we can advise corrective action.
Old 09-13-15, 12:57 PM
ray2047's Avatar
If it were me even if I had to open a ceiling I'd want to see what is below. That might very well determine the course of action. As written before it doesn't even look perpendicular.
Old 09-13-15, 01:48 PM
Previous flooring was ceramic tile over base mortar, the bathroom is on 2nd level.
Old 09-13-15, 02:01 PM
The flange seems level, possible the picture angle Name:  DSC_0027.jpg
Old 09-13-15, 02:13 PM
ray2047's Avatar
Didn't not putting in at least a layer of " plywood leave the bathroom below the adjoining room?
Old 09-13-15, 04:12 PM
czizzi's Avatar
This type of base mudbed is usually installed over a single layer of plywood. Many times 1/2" ply which is not sufficient for a nail down floor. An Additional layer of flooring underlayment should have gone down in advance of the finished flooring. This is for sufficient nail/cleat holding power. If the cleat blow out the bottom side of the ply, it has less holding power than if the serrated teeth on the cleat have 100% bite along the whole length. Not much can be done now unless you can screw the flange down to an acceptable level.
