two handled compression faucet
Old 09-26-15, 10:40 AM
I have in the bathroom of my home a compression faucet and the hot handle doesn't stop in line with the cold handle. The hot handle has to be turned until it is almost perpendicular to the cold handle. I am assuming I need to tighten something beneath the handle but I can't get beneath ir since there is no cap screw because the design of the handle
Old 09-26-15, 03:06 PM
Temporarily Suspended
If it's what I think it is, the outer portion of the handle, unscrews from the inner portion. Then you spin the inner portion as if you were turning on the water but don't stop. Keep going until the stem totally unscrews from the faucet body. Once you remove it, look at the bottom of the assembly. There should be a screw that holds it all together.
