Shower either has no hot water, or only gives very cold/very hot water
Old 10-03-15, 03:00 PM
D
Hello. I have read through the forums but didn't see a solution for this faucet type.
I have a Kohler faucet for my shower/tub. For the last week, any time we run the bath OR shower, we get one of two things: either no hot water even when turned up all the way (well a little warm but certainly not hot), or, cold water up until the halfway point and scalding water if nudged just a bit farther. During times with no/little hot water in tub, we can get it in the sink or any other faucet so it's not the water heater.
I saw that other forum responses asked for pics of the faucet, so I am posting them. I took the handle off to see if there was some piece I could adjust but didn't see anything. Still have issues even if you use wrench to turn the mechanism without handle attached.
Any suggestions?? Thanks
Old 10-03-15, 03:46 PM
Received 79 Votes on 74 Posts
There is no adjustment.
Very likely the balancing valve has trash in it.
Kohler will send you the parts for free if you contact them directly.
Old 10-04-15, 09:24 AM
D
Okay thank you I will do that!
Old 10-04-15, 10:09 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
replace the cartridge while your at it..
cartridge and balance spool shown...
Kohler GP76851 Pressure Balance Cartridge for Rite-Temp Style Tub/Shower Valves - See more at: Buy Kohler GP76851 Pressure Balance Cartridge for Rite-Temp Style Tub/Shower Valves
[ATTACH=CONFIG]56945[/ATTACH]
