Toilet too close to wall.
Old 10-07-15, 02:39 AM
Is there an easy way to move a toilet without digging up the floor and plumbing?
Can you move the toilet to a diagnal on the flange?
Thanks
Old 10-07-15, 03:22 AM
Received 120 Votes on 107 Posts
Welcome to the forums!
I'm not a plumber but I'm pretty sure the only way you can move the commode forward is to move the flange/pipe forward. If you turned the commode on the flange one end would come away from the wall but the other would be pushed into it.
Old 10-07-15, 05:22 AM
Received 192 Votes on 178 Posts
A toilet actually sticks back further if placed on a diagonal. There are offset toilet flanges that can move the toilet a couple inches but that gets into some mild piping/plumbing work. You can also look for a toilet that does not stick back so far.
Old 10-07-15, 06:32 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Why is it too close to the wall? If you explain the problem we might be better able to help you. How about some pictures. http://www.doityourself.com/forum/li...rt-images.html
Old 10-07-15, 08:04 AM
Ray has a good point. Perhaps you have a 12 inch toilet and a 10 inch rough in.
