Stand Up Shower Glass Door too Short
We just moved into a new place and have found that the master bathroom's stand up shower's glass door is about an inch and a half above the bottom of the shower. This is resulting in a lot of water getting out of the shower and onto the floor.
In the past I've had a plastic strip that screws into the bottom of the door to prevent this problem but this door has no screw holes so that seems out of the question.
I'd love to avoid having to replace the whole door - any ideas on what I can do to the door/shower to keep the water in the shower?
Thanks!
Thanks!
Some pictures of what you have might help as well: http://www.doityourself.com/forum/el...-pictures.html
When you say "glass door" is it a heavy glass door (thick glass with no frame) or does it have an aluminum frame around glass?
