Caulking a shower stall
Old 01-23-16, 02:54 PM
Question Caulking a shower stall
Can phenoseal be used in a shower stall . Also will it bond to silicone.
Old 01-23-16, 03:06 PM
chandler's Avatar
Any sealant you have now (silicone or other) will need to be removed prior to applying any product over it. The reason for this is the original application will have moisture damage and mildew/mold already growing on and under it. Applying another coating over it will only cause the mold and mildew to show through in short order. Phenoseal only has a 6 year warranty, so it says something of itself there. GE Silicone II is a good product for showers, although silicone is not soap and water clean up as is Phenoseal.
Old 01-23-16, 04:10 PM
Can phenoseal be used on the base of the shower stall & bond to silicon that is on the vertical parts of the panel coming down.
Old 01-23-16, 04:58 PM
Temporarily Suspended
Phenoseal is worthless IMO. What's the exact problem?
Old 01-23-16, 05:04 PM
Pulpo..... when you make a statement like that...... explain it.
Phenoseal is water based and should not be used in the presence of continuous water or where it will always be wet.
You'd want to use a silicon based sealant preferably with a mildewcide additive.
Old 01-23-16, 06:14 PM
I guess that was my mistake. What is the correct usage?
Old 01-24-16, 02:35 AM
Phenoseal is decent caulk but like all caulks it has specific uses with a shower/tub not being one of them. It's good for most any caulking job that includes painting.
Old 01-24-16, 05:37 AM
chandler's Avatar
I merged the two threads. No need to have more than one going on the same subject.
Old 01-24-16, 06:47 AM
Ok, thanks__________________________
