What shower valve do I have?
What kind of shower valve do I have?
Can I use this trim on it?
Grohe 19457001 Concetto Pressure Balance Valve Trim - - Amazon.com
Thank you!
JV
Welcome to the forums! You have a "sideways" one. No seriously, Mike should be along with his information,as he can probably identify it better. Hans Grohe makes a similar one, but difficult to tell. One question, or more.... are you remodeling? Is the piping polybutylene? I ask because it is problematic.
Thank you very much! It is hard to tell--if it makes a difference, I am hoping it is compatible with the Grohe I mentioned..
I hadn't intended to remodel, except in the minor sense of replacing the trim. But if there's a more serious problem, I have a plumber coming out next week, and I'll ask him about the piping.
JV
JV
I dont know what that is.. I would need to see the original trim and handle to tell.. And if I cant tell then I would need to see the cartridge removed...
If removing the cart then get the P/N off it..
Found it!
http://assets.kentrol.com/pdf/PRO5400.pdf
Looked inside the handle and went from there.
Thanks!
JV
Thanks!
JV
