Toilet shutoff valve
Old 04-25-16, 06:55 AM
P
Replacing a toilet and I have everything done except for the feed line. I'm having trouble getting the existing (and too short) line off the shutoff valve. When I use a wrench to loose the nut, it actually spins the whole valve. Any advice on how I can break the nut loose so I can remove that line and install my new one?
I did try using a pair of pliers to hold the valve, but it keeps slipping off.
This is what I've got:
Old 04-25-16, 07:05 AM
Received 77 Votes on 72 Posts
Need an open end wrench on the valve not plyers.
You are turning the nut to the right, correct?
Your replacing that old supply line with a braided one I hope.
Old 04-25-16, 07:14 AM
P
Joe...I'll find another wrench and try that tonight when I get home from work.
Quick question (And I'm probably being dumb by asking), why turn the nut to the right to loosen and not to the left?
And yes...I have a brand new braided supply line ready to go.
Thank you!!!
Old 04-25-16, 08:03 AM
Because it's a right hand thread and it's the only way to disconnect the line.
Old 04-25-16, 09:20 AM
C
Received 96 Votes on 75 Posts
Hold the valve with a wrench and turn the nut CCW. "Lefty loosey - righty tighty"
Old 04-25-16, 09:56 AM
G
Received 1 Vote on 1 Post
Thanks for posting that picture. A month ago I asked how to trim a floor-mounted valve on PEX and it's nice to see the answer.
