Bath Sink Drain "Burps" Occasionally
Old 05-05-16, 02:18 PM
My bath sink vanity generally drains pretty fast (say 4 our of 5 times), but occasionally water will accumulate in the sink, followed by a few big "burps" of bubbles. So, I took apart the trap (PVC slip joint style), and removed a few minor globs of the usual "grey goo", and sloped the waste arm downward (it was going slightly uphill, rather than downhill). I thought doing that might cure the problem, but it didn't. Anyone experienced this before? I'm wondering if maybe its a clogged vent issue, but I thought I would run it through the forum before getting on the roof and sticking my snake down the vent pipe. Thanks in advance.
Old 05-05-16, 04:57 PM
Received 108 Votes on 95 Posts
No one here is going to know how your home was plumbed, how old the home is, without more info.
New to you home?
New issue?
Old 05-05-16, 05:50 PM
Handyone's Avatar
I don't know about a burp. A gurgle indicates clogged main drain.
If your house has cast iron pipes, changing out the san tees to ABS will make water flow much better. The cast iron tees have a sharp drop off that collects build up over time and will remain a problem.
