Need advice for replacing faucet line
Old 05-15-16, 02:43 PM
spirittoo's Avatar
Received 1 Vote on 1 Post
Question Need advice for replacing faucet line
A cold water line under a sink in the bathroom is leaking and needs to be replaced. Can anyone tell me what size and type wrench I need to use to get the hose loose?
Do I remove the top part of the line from under the sink or do I have to lift up on the sink and reach it that way? Will that be a tight fit to get a wrench in at the top from under the sink? Is there something I can use if the nut won't turn?
I found this at Home Depot's site, will it work for me? If not ... what would?
How hard a job would this be for someone that has never done it before?
Thanks for reading my post.
Old 05-15-16, 03:57 PM
P
Temporarily Suspended
There is no need to remove the sink. You need a faucet wrench. Replace the entire flex connector.
Old 05-15-16, 04:07 PM
Norm201's Avatar
Received 230 Votes on 205 Posts
If that valve leaks after turning it off then it should be rebuilt or replaced. A small adjustable wrench should do the trick to remove the braided line from the faucet end.
Old 05-15-16, 04:24 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
The sink part if you can't get a wrench or pliers there this wrench is made for your job.
3/8 in. x 1-1/4 in. Telescopic Basin Wrench-70225 - The Home Depot
Old 05-16-16, 12:22 PM
spirittoo's Avatar
Question Is that the right faucet line?
Can anyone tell me if that is the correct faucet line for the sink in question? I have a link to in my last post? Is there something I can use if the nut is stuck and won't turn?
Old 05-16-16, 02:02 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
The sink has nothing to do with the line you use because the line goes to the faucet not the sink. Faucets are a standard " pipe thread so they aren't a real concern either. Most sink supply valves are either 3/8" compression or 3/8" flare or. The two types are not interchangeable. However your link is to a universal supply line so it should fit due to the adapters.
Never seen one stick but a cheater pipe on the basin wrench handle should do it if needed.
Note toilet supply lines look a lot like faucet supply lines bur won't work. They have a 7/8" end not a " pipe thread end.
