I can't remove a tub drain cap!
Old 06-23-16, 01:26 PM
crabjoe's Avatar
I'm assuming it's a Moen push/Pull drain lift and turn drain and I can't remove the cap to replace the drain.. The chrome is flaking off..
It looks like the below and what's the trick?
[ATTACH=CONFIG]67653[/ATTACH]
Thanks!
Old 06-23-16, 01:56 PM
chandler's Avatar
Received 6 Votes on 6 Posts
The cap screws into a nylon or metal receiver/strainer. Once you pull up on the drain, just unscrew it. If it does not cooperate, you will have to look into the opening to see if it is free spinning and use a screw driver or other object to keep it from happening, but usually unscrewing it using the knurled handle works.
Old 06-23-16, 03:27 PM
crabjoe's Avatar
Are you saying the complete cap should unscrew or just the little handle on top? The complete cap just spins and spins...
Old 06-23-16, 03:40 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Just the handle uncrews. You have to hold back on the cap...
Old 06-23-16, 04:09 PM
crabjoe's Avatar
Thanks folks... I'll give it a try over the weekend.. I'm to dang tired to try it right during the week.. To much stuff going on.
