Help! Unable to stop leaking shower tap!!
Old 06-26-16, 04:19 PM
E
Hi
Hope you can help.
My shower tap has been increasingly leaking. I'm not sure if the bolt (where the leak is coming from) can be tightened and i dont want to accidently bend the pipe going into it in an attempt to tighten it.
Can anyone advise why there is now a constant (almost stream of) dripping and whether i need to call a plumber or if its something I can fix myself?
Thanks
Old 06-26-16, 05:02 PM
C
Received 2 Votes on 2 Posts
Gently tighten the nut with a wrench. You won't hurt anything unless you really force it.
