Wall Mount Pumps on the shower tile?
Old 07-09-16, 03:57 PM
Can I install simplehuman® Triple Wall Mount Pumps on the shower tile? I show you
Old 07-09-16, 04:45 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
What would the mounting method be? Screws or adhesive. What does the manufacturer recommend? If screws do you have a drill and a diamond bit? How much does it weigh?
P
Received 601 Votes on 555 Posts
That depends on how you mount them. Something like double sided tape should be fine.
Old 07-09-16, 06:34 PM
The manufacturer recommend uses adhesive on the shower tile. If I change my mind, I remove the simplehuman® Triple Wall Mount Pumps. Is it easy to remove or hard?
Old 07-09-16, 06:47 PM
Norm201's Avatar
Received 227 Votes on 202 Posts
Double stick tape should be easy. You might need a razor blade to scrap off residue, but you won't harm the tile. I had one of those Simple Human soap pumps. Didn't last long.
Old 07-09-16, 06:55 PM
Thanks everybody
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
