Toilet that keeps running?
Old 07-28-16, 07:38 AM
How do I fix my toilet that keeps running if I flush it?
Old 07-28-16, 07:43 AM
P
Received 969 Votes on 890 Posts
First you need to figure out if it's the flapper valve or the fill valve that are leaking. Pull up on the float inside the tank. Does the flow of water stop? If yes then you need to replace the flapper valve. If water continues to flow when you're lifting the float then the fill valve should be replaced.
Old 07-28-16, 11:35 AM
Thanks,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
