See lot of black stuff inside my toilet tank ?
I checked it out my toilet tank and I saw lot of black stuff inside. Do I clean it if so what kind of tool do I use to pick them up?
I would not worry about it. If it worry's you you could shut water off and flush toilet and than clean the rest with a wet, dry vacuum.
Do you have well water? Looks kind of like sand particles that are not uncommon from a well. Do you have trouble with aerators plugging up?
Otherwise as Pugsl said, not a real problem for the toilet...
Looks better then most tanks I've seen.
Sure looks like you have an old style ball ****, not a newer style Fluid Master flush valve, not going to fix you minor issue but when that one starts to act up this is what you need to change to..
