Little or no water from faucet.
Old 08-15-16, 02:06 PM
W
There is few drops come from my bathroom sink tape today, when I turn ON. I try to TURN OFF and TURN ON two inlet valves (hot and cold) below sink, no lucky. IS there any other easy steps I could take before I have to replace the tape?
Old 08-15-16, 02:15 PM
lawrosa's Avatar
Super Moderator
Received 69 Votes on 61 Posts
What is a bathroom sink tape? Possible we can help...
Old 08-15-16, 02:53 PM
XSleeper's Avatar
Received 988 Votes on 899 Posts
I'm guessing he/she means tap, or faucet.
Old 08-15-16, 03:16 PM
Handyone's Avatar
The easiest step is to unscrew the aerator and clean it or replace it, it might be severely clogged.
If that doesn't work you need to remove the supply lines from the faucet.
Remove the lines from the faucet and keep them connected at the valves.
Place the lines in a bucket, turn the water on, and see if any water is coming out of the wall.
Old 08-19-16, 10:11 AM
W
Thanks. How to find aerator? I only see two lines from cold/hot valve, then joint to tap inlet. I'll try to remove lines from the faucet and follow your suggestion this weekend. Is it possible I have to replace hot/cold valve?
Old 08-19-16, 10:15 AM
XSleeper's Avatar
The aerator is the filtration screen that the water comes out of when you turn the faucet on. It unscrews... you will want to use a pliers and can cushion the pliers so it doesn't scratch. An old rubber glove helps cushion.
once the aerator is off, see how the water flow is and go from there.
Old 08-19-16, 10:59 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Aerator is at the end of nozzle. It will screw off. It is a screen in the cap. Here are several types
http://www.lowes.com/pl/Faucet-aerat...ing/4294639566
Old 08-24-16, 11:08 AM
W
my kitchen faucet has aerator (screen), but my bath room sink tap does not have. I have removed hot/cool pipes under sink, there is water. After connect to faucet again, there is no water. What is the next?
Old 08-24-16, 12:05 PM
pugsl's Avatar
Is the problem with both hot and cold water?
Old 08-30-16, 11:56 AM
W
I found one similar to aerator, it is not screwed with tap, I pulled it out from tap, water comes, but I can't push back fully as showed in attached picturesName:  tap3.jpg
Size:  12.1 KBName:  tap1.jpg
Size:  18.5 KB. How can I push it back? I did not push very hard
Old 08-30-16, 01:07 PM
pugsl's Avatar
Can't tell anything from picture need to see the other side.
Old 09-01-16, 08:18 AM
W
should I pull it out again to see its back?
Old 09-01-16, 08:22 AM
W
I try go to Home Depot to find similar tap, but no lucky. Where can I find such tap? I may damage the tap because pull it too hard with tool.
