Should I use two wax rings?
Old 08-23-16, 10:20 AM
P
I have a new toilet that sits on a 3/4" hardwood floor. The top of the flange sits 3/8" below the surface of the floor. Will this gasket do the job, or should I put a plain wax gasket on top? Everbilt Extra Thick Wax Toilet Bowl Gasket with Flange-7513 - The Home Depot Dimensions for the gasket are: wax is 1.25 inches thick, and the gasket flange protrudes about 1/2 inch from the bottom of the wax.
Old 08-23-16, 01:13 PM
P
Received 601 Votes on 555 Posts
It also depends on your toilet. Not all toilets have their sealing flange in the same location/elevation. I would try the thick one you linked and when installing pay attention for "squish". If the toilet plops down solid on the floor I would pull the toilet back up and add another plain ring on top. If when you set the toilet down it "hovers" 1/4" off the floor and you need to sit on it an wiggle to get it to squish down then I'd say you are good with just the one wax ring.
Old 08-23-16, 01:29 PM
P
Thanks. I'll give it a try. the funnel-shaped outlet on the bottom of the toilet is exactly level with the rest of the bottom.
Old 08-23-16, 02:51 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You could use a flange spacer on top of the flange.
Image source: mobilehomerepair.com
Old 08-23-16, 05:21 PM
P
I would give that a shot, but I already tried a regular size wax ring, and I would be concerned that I couldn't get all the wax off so that I could get a good seal between the spacer and the existing flange.
Old 08-23-16, 05:36 PM
ray2047's Avatar
Either way would be good but if you want to go with the spacer cleaning with alcohol after scrapping should be enough for silicon to seal.
