Glass shower door leaking
Received 0 Votes
Every time I shower waters leaks from my shower onto my bathroom floor. It is very easy to see that the water is coming from just below my swinging glass door (the gap between the door and the tile step). I have tried the plastic door sweep (see picture - I just removed it) but that still doesn't completely stop the leak. I have put a few of these on my door over the years and at the beginning they work ok..but as time goes on they wear out and the leak gets worse and worse. Even when the sweeps are new, water still gets through beneath this sweep at the grout areas as they are not completely level.
Is there anything else I can do so I can completely stop this leaking? At this point I am open to anything, including adding something permanent on tile right below the shower door to stop this.
Please help.
Please help.
Welcome to the forums! It probably isn't the sweep's fault, but the attitude of the tiles across the berm. Can you lay a short level across them to determine if they are pitched back into the shower or not?
