Leaking toilet - with new flapper and flush valve
Old 09-14-16, 09:39 PM
I
I got a Kohler two piece (Highline?) toilet that I recently noticed was running. I replaced the flapper (Korky). I replaced the whole flush valve assembly (I thought I ordered a Kohler OEM part but I got Flushmaster). The second replacement included a new washer and new gaskets both below the tank and inside the tank below/around the flush valve. Yet somehow the toilet is still leaking. I turned off the water and left it overnight; the tank was dry the next day so the leak is below the flapper level.
How do I stop the leaking?
Thanks,
Old 09-14-16, 09:56 PM
XSleeper's Avatar
Received 988 Votes on 899 Posts
Remove the tank from the toilet and replace the entire overflow valve and flapper as a unit.
Old 09-14-16, 10:01 PM
I
Yup. Did that. That was the second thing I did. The tank was completely dry this morning so the leak is around the base of the flush valve.
Old 09-14-16, 10:11 PM
XSleeper's Avatar
I would double check your work then.
Old 09-14-16, 10:24 PM
I
Yeah. I'm going to redo it all with some silicone gasket maker to help seal things in. That and sand the surface to make sure it's clean and smooth around the hole.
