need help finding unique flush valve that goes into non-removable tank.
Old 10-01-16, 03:36 PM
see pictures. its held by a screw and bracket making a seal. this is a bad system and it breaks like it did to another of my toilets which i was forced to repair with super glue. ive been told its an old style toilet but the house is 10 years old.
Size:  30.9 KBName:  20161001_124949.jpg
Size:  20.2 KBName:  20161001_125001.jpg
Size:  21.4 KBName:  20161001_141857.jpg
Size:  15.4 KBName:  20161001_141910.jpg
Old 10-01-16, 04:51 PM
C
Received 2 Votes on 2 Posts
This one seems pretty close...it would help if you know the toilet manufacturer. It's often printed inside the tank lid.
2 inch single flush valve for one piece toilet
If that one's not right, start by searching for one piece toilet flush valve to get more options....
Old 10-02-16, 05:56 PM
thank you! that seems the right kind but mine is 3". The height is a HUGE factor because the tanks are so short. also the toilet mfgr cannot be found anywhere!
Another thing is that they dont stay up by themselves and you have to hold them down. Is there supposed to be something floaty in that cylinder?
Old 10-02-16, 06:28 PM
C
Post a picture of the whole toilet...good chance someone here will be able to identify it.
Usually that cylinder fills with water when down. When you flush, it flips up with the top above the water line. Water drains out the holes until it gets light enough and the weight of the bottom part flips it back down. Etc, etc.
Old 10-02-16, 06:33 PM
i cant remember if it ever held itself before but it hasnt in the past few years. is there any remedy?
Old 10-03-16, 03:48 PM
do you know if its possible to fix the floating mechanism? thanks.
Old 10-03-16, 04:51 PM
pugsl's Avatar
Received 76 Votes on 69 Posts
If float is bad it is a easy replacement. Here is one type, there are many different one's
Shop toilet float at Lowes.com: Search Results
Old 10-07-16, 08:52 AM
its not like the ones you listed since though. those flush valve floats cant be installed onto this (see pics below)
