Squealing pig shower
Old 10-23-16, 10:19 PM
Received 2 Upvotes on 2 Posts
Hi folks,
Any suggestions here would be great. We have a shower that squeals like a pig and makes high pitch sounds when you use it. It almost always happens when you start the shower, and then comes and goes as you take your shower. I tried running it for a few minutes on just the bathtub faucet and messing with the water strength before diverting to the shower head, but that didn't work.
Any thoughts?
Old 10-24-16, 06:03 AM
P
Received 1,952 Upvotes on 1,748 Posts
Can you tell if the sound is coming from the shower head or the valve area?
Old 10-24-16, 06:12 AM
Received 126 Upvotes on 111 Posts
Clogged shower head causing back pressure.
Water pressure to high, simple to check.
Winters Instruments PET-LF 2.5 in. Lead-Free Brass Water Pressure Test Gaugewith 3/4 in. Swivel Hose and Maximum Pointer and 0-160 psi/kPa-PETM213LF - The Home Depot
Loose washer if it's the old style two handle.
Old 10-24-16, 12:14 PM
Hi folks,
Thanks for the replies. I will find out if the sound seems to be coming from the shower head or the valves. It definitely could be clogged too since it's about 4 or 5 years old and we have very hard water.
Stay tuned!
Old 10-24-16, 04:10 PM
P
There is a flow restrictor in most shower heads and a balancing valve/cartridge in the valve body. Both can make noise under some cercumstances.
