How do I fix my bathroom sink faucet?
Old 12-01-16, 02:02 PM
When I turn the cold water knob the base moves with it. Do I need to get under the sink and clamp the bolt down and twist the base to tighten it?
Name:  2016-12-01 15_58_51-20161130_221808.jpg - Windows Photo Viewer.jpg
Size:  31.4 KBName:  2016-12-01 15_57_52-20161130_222023.jpg - Windows Photo Viewer.jpg
Old 12-01-16, 02:58 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Remove the handle and let us see what you have under it holding the decorative trim down. You may want to remove the other one too in order to compare them.
Old 12-01-16, 03:21 PM
Handyone's Avatar
Yes, you need to tighten from below. Here's a standard diagram.
It helps to have someone hold the valve in position while you tighten the flat nut marked F.
Pay attention to the 2 wrenches in the bottom left of diagram.
Old 02-07-17, 09:01 AM
I tried a regular size wrench but it's too big to fully turn.
What type of wrench can I use for this purpose?
Old 02-07-17, 02:07 PM
chandler's Avatar
You may find it easier to use a basin wrench such as this. HDX Basin Wrench-UWP0003D - The Home Depot It allows you to wrench it from below rather than laterally. Those pictures are taken in an ideal situation with the sink out of the hole.
