How to replace toilet chain
Old 12-30-16, 12:22 PM
The toilet chain snapped in my toilet, and as i was going to replace it, i cant seem to remove the old one from the flush lever. Is there a special technique to removing it, or am i supposed to reattach the new chain to where it broke off?
Old 12-30-16, 01:00 PM
T
You can't just add more chain because the flapper will probably stop working properly. Often you can reconnect the chain with needle nose pliers.
Replacing the chain should be a simple affair. Chains often have a pin you remove. If possible, send a photo.
Old 12-30-16, 02:14 PM
chandler's Avatar
Can you post a picture of what you are seeing. Remember we are blind until you enlighten us. http://www.doityourself.com/forum/el...your-post.html
