Water leaking from under disposal
Old 12-30-16, 04:30 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi All, water is leaking out of bottom of disposal,anything I should check before I replace it?
Geo
Old 12-30-16, 04:34 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Output connection. Attachment ring to sink. Where is it leaking from. If from the bottom hex hole area, it may be toast. How old is it?
Old 12-30-16, 04:59 PM
Handyone's Avatar
As Larry said, it's toast if you're sure it's leaking from the bottom.
Disposers can look pretty good from the outside and be ruined inside.
I toss them all the time and convince customers to purchase a new unit while work is being done, you'll be good for many years.
Old 12-30-16, 05:28 PM
Geochurchi's Avatar
Leaking right out of the bottom,it's toast,just wanted to be sure, don't know the age.
Geo
