Glacier bay toilet repair
Old 01-08-17, 12:56 PM
I have a one piece Glacier Bay toilet and I want to replace the valve and flapper. The fill valve is not a problem, but the flapper assembly is something I've never seen before and cannot identify parts. If you pick up the flapper, there are 3 brass screws that the assembly screws into. Does anyone know where to buy this flapper assembly? The toilet is from 2007. Thank you
Old 01-08-17, 01:30 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums! Technology changes, so could you post a picture or two of the inside of the tank for us so we can see what you see? Mostly all the one piece toilets are dual flush type. http://www.doityourself.com/forum/el...your-post.html
Old 01-08-17, 02:17 PM
Size:  29.1 KB hopefully it's attached
Old 01-09-17, 04:49 AM
chandler's Avatar
The flapper should be independent from the base you are showing. The three screws hold the assembly down. The flapper should detach at the pivot point and a new one will pop right in. I see no need based on the picture to replace the lower part. Fluidmaster 3 in. Toilet Tank Flapper for Glacier Bay-5401GBP4 - The Home Depot
