Level Floor for Tub?
Old 01-26-17, 08:03 PM
C
So, had to have a pipe under concrete repaired by the plumber chosen by the Condo Assoc. When completed, he didn't level the cement. The "contractor" I hired said he would level it and used some quick cement that I had. It ended up higher on the ends than in the middle. Next, he wanted to skip using the 2" of mortar recommended by Sterling to install this Ensemble tub. I feel the mortar became more important than ever and am not sure I want to let this guy continue. Can I count on the mortar to help level or do I need to hold up this project and get a level surface first?
Old 01-27-17, 02:15 AM
Marq1's Avatar
Received 371 Votes on 346 Posts
If your comment relates to the mortar/cement bed used to set the tub then you are absolutely correct.
Without you will not have a solid base, it can flex and possibly crack with time.
In addition it will just not feel solid (had a shower once). Feels cheap!
Old 01-27-17, 06:33 AM
Received 77 Votes on 72 Posts
No mortar, no warranty.
Really think he's going to come back and replace the tub for free when it fails?
